Results 1 to 10 of 10
Thread: transmission tuning question
    HotRodV6 Guest
    ok, one thing that is driving me crazy on my 03 silverado is under light throttle low speed driving the 1-2 shift seems to come out of 1st and "drop" into 2nd with a clunk. The truck just turned 58K miles today, and im not sure if the fluid has ever been changed, but a full fluid flush is on my short list of maintaince stuff to do.
    I want to find out if its better to tune the PCM for better shifts, or install a transgo HD2 kit. I have a brand new kit here already that i bought for my previous car that got totaled, and never got to install it. Im not looking to bark the tires on every gear change, but i do want firmer than stock under light throttle, and maybe alittle chirp on the 1-2 shift at WOT, but nothing that will be neck snapping as the wife will just say i ruined it by messing with it.
    I do have some bolt on mods planned for the future, but probably wont go beyond that with the stock 5.3.
    ff_jeff Guest
    ide change the filter/ fluid. get the shift kit and the tune.
    HotRodV6 Guest
    yeah i think im going to go ahead and do the shift kit, since i already have it, and put in a new filter and fluid, and if i want to firm up the shifts after that i can do it with the tune, i also def want to get the TM tuned out.
    ff_jeff Guest
    just have allen do it nelsonperformance.com he did mine and it hauls now. Btw dont tune out all of th TM if you do it your self. unles you want an excuse to rebuild it, cause it will pop
    yeah as far as the clunk you here when it shifts, that actually will get worse with more firmness added!! You really have to make sure the shift firmness is in a good spot for a 4l60. Too much firmness and out goes the tranny from high line pressures, too low and you slip
    Jun 2007
    Quote Originally Posted by HotRodV6 View Post
    GET A VETTE BILLET SERVO AND TUNE THE TRENNY LINE PRESSURE FIRST THAT CAN BE UNDONE IF ITS TOO MUCH THE TRANS GO CAN BE VERY FIRM SOMETIMES TOO HARD AND ITS NOT EASILY UNDONE.LINE PRESSURE CAN BE ADJUSTED UP OR DOWN,AND THE SERVO TAKES A WHOLE 5 MIN TO INSTALL ,TRUST ME DO THIS FIRST.MY 2 CENTS
    HotRodV6 Guest
    Quote Originally Posted by ramsey rider View Post
    yeah, i just ordered the vette servo, and im going to pu tut in the HD2 kit, it has different shift settings, i remember from the one i put in my 01 Blazer X, there are 3 settings, i set the blazer up on 2, and under normal driving was firmer than stock but not harsh, and it shifted pretty hard under WOT, but the TM was really bad and the truck fell on its face on a 1-2 shift, especialy after i put in the 4.10 gears.
    Im going to start with the HD2 kit and vette servo and im def going to get a tune and get the TM mostly tuned out, so i dont have the same problem.
    May 2007
    Oshkosh, WI
    Does anyone have the Corvette servo part number handy for a 4L60E?
    It should be in the transmission topic that is stickied.
