Results 1 to 10 of 19
Thread: LT1 El Camino
    Dec 2003
    Thought I should go ahead and put this conversion in the right section.Had it in Pics/videos cause someone else started it there.Rest of my parts are somewhere in Alabama and supposed to be here tomorrow,I hope Oscar put everything in the package.Anyway,see if I can get it to the exhaust shop tomorrow.Nobody's given any comments on the Crossover or X pipe.Have to trust the Muffler Man I guess Here come the Pics again.
    Dec 2003
    Anybody have a wiring diagram of an '82 El Camino that can look up the ground to the check engine light.I have an '83 diagram and it shows to be Yellow
    Dec 2003
    Anyone tell me which oil sending unit will work with a gauge and has one wire for an '83 set of SS gauges.
    Dec 2003
    See if I can drive it tomorrow. Of course everthing else has gone wrong,so this will be an experience.
    Oct 2003
    Its a slow forum man, check out fullsizechevy.com they have a exhaust section... great forum too youll find what you need.
    San Marcos Texas
    I'm not sure if anyone here has a crossover pipe or X to comment on.
    Dec 2003
    Finally got to drive it.Pretty impressive.
    Dec 2003
    Thing runs pretty gooooood Have to drive around with a scan tool hooked up right now. Check engine light will burn your eyes.Got a bunch of codes in it.Had 3 hard codes,got it down to 1.Picked up a surge though,believe I put the wrong EGR Valve on it,got one out of the bushel basket.Think I got a negative on it,and I think that's what it takes.Might have gotten a weak one or need to shim the orifice.I put the O2 sims on it about the same time,don't think that would have anything to do with it,but did get D codes for both rear O2's for insufficient activity.EGR code is gone.
    Anyone scan any O2 sims.These don't change,think I installed it right.It's a dual O2 sim
    Have to keep working on it,at least it goes after 5 months
    put a block off plate on the EGR and that will let you know if you had a leak or something. I blocked mine off from day one and it made no difference since I was not using the EGR tubing from the exhaust or smog pump. I would suggest you buy one of Street and Performance's prom chips. They are programmed for performance and they will delete the smog feedback and anything else you want deleted or added. Not to mention they are only about $69 last time I checked.
    Dec 2003
    Going to try the old EGR on there,it didn't work so that should block it off.Can't run a chip OBD II.Need LT1 edit,but spent all my money.Little ole swap is getting close to $3500 or better,afraid to add it up.
