Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 68
Thread: auburn lsd...
    Jun 2006
    auburn lsd...
    so im looking at getting an auburn lsd... what one do i need to get???
    Aftermarket - Products - Differentials - Pro Series
    am i looking in the right place?
    and do i want the pro series? or the ecd???
    05 Chevy Silverado. Regular cab, short bed.
    -4.3L
    - Sung Top tonneau bed cover.
    imco custom dual exhaust,
    custom air intake,
    ls1 build in progress..
    8.5 & 8.6, 10 Bolt
    All GM products with 8.5 & 8.6 ring gear
    (Large bearing hub, includes bearings)
    2.73/up
    30 Teeth
    1989 - Present
    Yes
    Call 4Wheelparts.com and see what their current price is. They're running them on special right now.
    Jun 2006
    well for the full time aburn lsd with 4/10 gears installed.... they want $1,142.62????? does that sound like a good deal?
    any other ideas... also what kind of 4/10's should i get.. i drive this truck daily... and want awesome accleration but with good top end.. do you think 4.10's are the way to go... or are 3.73's better for what i want.
    -4.3L
    custom air intake,
    I have paid 1500.00 installed before. Check with Nelson Performance of TRT they might be cheaper. If you are close to them.
    do it yourself.... all you need is patience and a good memory
    Jun 2006
    yeah but dont you have to measure backlash or something like that?
    -4.3L
    custom air intake,
    There is a few more things in addition to the backlash...pinion depth, pinion bearing preload, and carrier bearing preload. Shims are used for correct spacing, but each rear end is slightly different, so you have to use a micrometer or dial indicator to get specific depths. It's a pretty intense install unless you know exactly what to do...
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    That's maybe $75 in tools, cheap.
    I don't think the 4.10s are going to help you any with topend.. I might be wrong but the higher the gear, the more you lose topend
    You want to be at the top of the RPM in your chosen gear when you trap.
    Do you even know what kind of times you'd pull to run a 130mph trap? Many 12 sec rides only trap mid 100 teens.
    Jun 2006
    Quote Originally Posted by Hit Man X View Post
    i no i cant run 130 on the track.. but i was just wonderin if 4.10s would like limit my speed to like 80 or something... im not saying that with those gears i expect to be running insane track times.. lol... anyways ya i think im getting the lsd tommorow.. and then im gonna get the gears a few days later.... is this the lsd i should get? http://www.4wheelparts.com/PPT5457T5589.aspx
    what one should i if those are the right ones? and also will my towhaul button work with an aftermarket diff?... i dont car if it does or not id just like to know..... thanks guys..
    -4.3L
    custom air intake,
    Apr 2003
    Thumbs up
    Quote Originally Posted by 05chevyguy View Post
    i no i cant run 130 on the track.. but i was just wonderin if 4.10s would like limit my speed to like 80 or something... im not saying that with those gears i expect to be running insane track times.. lol... anyways ya i think im getting the lsd tommorow.. and then im gonna get the gears a few days later.... is this the lsd i should get? Limited Slip Differential
    Then how would a 4.10:1 limit you to 80mph? This does not make sense.
    The 130mph was with a 6000rpm limit, 30" tires.
