Results 1 to 10 of 13
Thread: i upped my boost ?
    Jun 2007
    i upped my boost ?
    well i decided i was going too push it a little more ,i went from a 3.33 pulley to a 2.87 pulley nice difference in power.actually SWEET. NOW .what i didnt realize is now i have more backpressure and when im on the highway at 80-90 mph i seem too be feeling backpressure and i never did before,when i go too slow down i feel it bigtime .is this something too worry about ,if so how do i treat it?im pretty sure its normal when adding compression .do they make a blow off valve or something like that.any precautions or info would be appreciated.o im also obviously seeing higher intake temps.is this a major concern what are considered adequate ,safe iats at cruising speed or even in town with this kind of boost?thanks.am i damaging anything ?
    Jun 2007
    C,mon Are Ya Kidding Me ,i Thiught I Was Going To Bed Early!all The Guys On Tonight.lol
    You can put a blow off valve in the intake pressure tube if you want to guaranty that you don't overboost. Did you adjust the tune for the added boost? Are you monitoring knock? Are you watching the AFR since the change? Gotta be careful with the added boost.
    Jun 2007
    thanks red ya ive been monitoring,everything,
    Jun 2007
    any other suggestion or helpful hints
    I think Red covered it...
    Jun 2007
    can anyone tell me what kind of blowoff valve ?i dont want something noisy ,like some ive heard.and just too be clear i dont mind the boost im not looking too blowoff the boost im looking too release the compression as rpm s drop .im not sure how too do it any input appreciated or links would be nice .
    Jul 2007
    eastern shore of virginia
    well, i have a procharger and a it had a bypass valve with the kit but i replaced it with a turbo xs RFL and its VERY loud but it does release the boost when i let off the throttle. you REALLY HEAR it. scares the hell outta people. you could possible get a recirculated valve from an aftermarket company
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    Jun 2007
    ya i think thats probly what ill have too look for ,i dont want a rediculous sounding blowoff,now i just have to find one .tanks any suggestions for aftermarket recirc valve or something that might not be noisy?
    Dec 2005
    Chicago-ish
    What does back pressure feel like?
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
