Results 1 to 10 of 12
Thread: posi rearend ideas?
    Mar 2004
    KY
    posi rearend ideas?
    whats a good posi rearend that i can do donuts with and posi burnouts without ti kickin one wheel. prices adn ideas helpful, thanks ahead of itme.
    96 Silverado rcsb
    5.7l Vortec
    Exterior: 2 inch drop shackles, Centerline Titan 20" Wheels, clear lights, Debadged.
    -Exterior to come: 2-4 drop, Tinted windows, Cowl hood, Green Calipers
    -Performance mods: Flowmaster True Dual exhaust
    -Performance to come: Tune, CAI, Cam, Spray, Posi, gears, stall, headers.
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    Anything other than stock.
    Aug 2005
    St. Anthony, Indiana
    Eaton posi, Detroit truc trac
    "Tru" dat! Those are the only two that I would recommend. And If I could pick one...Detroit.
    I've never tried those two but have had great success with the Auburn, other than a used one I bought off of Ebay I should have known better than to buy a used posi!
    Mar 2004
    KY
    how about one out of a facotry 4wd truck? those will lokc enough to do a nice smoky burnout,get good traction and stay posi in donut fun?
    96 Silverado rcsb
    5.7l Vortec
    Aug 2005
    Quote Originally Posted by 1fastsilverado View Post
    nope, those are G80's and they will eventually explode on you.
    NNNNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    Pics from my Z71 You should have heard the kaboom. Everything was broke from the rearend all the way to the transfer case.Had to replace drive shaft yokes joints everything.
    Slimsilverado Guest
    OK an Eaton will wear out pretty fast they are a clutch and steel type posi alot like u would c in a automatic transmission, true track seem to be ok but a worm gear rear end is likely to explode under hi hp with slicks. An Auburn HD would be the way to go in my opnion. They hook up great and you can have them rebuilt.....
    You can't rebuild an Auburn but if you burn one up while in warranty they will replace it for about $120. That's cheaper than the rebuild/re-clutch charge on any other diff.
