Results 1 to 10 of 14
Thread: Rough Ridin' Crew Cab - Shackle drop only
    Jul 2007
    Pleasanton, TX
    Question Rough Ridin' Crew Cab - Shackle drop only
    Hey,
    Anyone else have a rough riding truck? My Dad's X-cab rides nice...but my CC rides like a brick! Any bumps are magnified X100 and it even chops around sideways sometimes. My wife says she doesn't feel safe in it!
    Stock CCab with 285-55-20s and 2" lowering shackles on back. Are the wheels making the unsprung weight an issue with the ride? I bought the truck in this condition...just need to try to make it better!
    '-05 people haulin' 5.3 crew cab. Nelson Tuned! 17.4MPG @ 75MPH...SLOW, but not bad.
    Jan 2006
    The only thing I can think of is the pinion is at the wrong angle. Do you get any popping in the rear when you get on it. The 20's don't help either. There is not much rubber b/w the rim and road.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jul 2007
    Pleasanton, TX
    popping? no
    No, no popping noises...
    The research I've done suggests to trim the bump stops on the rear axle...is that the norm for a leveling shackle install? Mine are not trimmed.
    I'm tempted to get a stock set and put it back original...do like the look of it now though...
    If you are in SA, I'd like to take a ride in that monster! slide the baby seat over!
    Crawl up under there and check out the front suspension. Being that you're in the SanAntonio area, the truck may have made a few trips to the beach and got salt in the suspension - rusting it away and possibly locking up the shocks and suspsension. You may have to replace the front shocks or aarm bushings to fix your problem. I'd suggest a set of Monroe gas shocks on there, the factory ones just never do it for me. If you have visible rust and corrosion in the front suspension you may want to stop it by having the suspension soda blasted and painted with a rust convertor paint like paint over rust POR products. You could have some dry ball joints, also.
    Jul 2007
    Pleasanton, TX
    Truck hasn't seen much road miles. I'm more concerned with the rear suspension. It seems a little stiff to me. I put a load on it and it hardly squats.
    The springs look stock but i'm not sure. Front seems to do Ok. Rear is choppy and bumps along the hiway at speed. I'm thinkin bump stops need to be trimmed but am not sure if this is a normal practice for just leveling shackles...May do it anyways...cut half off and see how she rides.
    trim the bump stops and see if it helps. It is a free mod.
    If that does not help should have Allen drive it, A professional opinion may be in order.
    The rear end of every GM truck I've ever driven is choppy on certain kinds of roads. To soften the rear end up you could remove the overloads, unless you haul heavy loads.
    Dec 2005
    Houston,TX
    Like red said b4 try a different set of shocks. My buddy has a cc like yours but a little lower and he had the same problem as you in the rear. Dont know what kind of shocks he went with but as soon as he did that it was night and day. Way better ride.
    Jul 2007
    Pleasanton, TX
    Thanks guys, I appreciate the opinions on this subject.
    Guess Ill just take out the bump stops and see if that helps...then go with new shocks if it doesn't.
    (stops will be reinstalled-trimmed)
    DBYRD Guest
    my truck rides rough as well, but i have 20's and drop shackles as well. i know i need new shocks all the way around, but will prob wait for a drop to replace them. bump stops will get cut tho. when u figure out what makes ur truck ride so rough post up im very interested in this thread!
