Results 1 to 5 of 5
Thread: something wrong with truck..
    Southern California
    i was driving to work today, when all of a sudden the motor started surging really bad, and eventually stalled on me. after trying to start it, it would start but then eventually stall a few seconds after. what could this be?
    2007 NNBS 4.8 -k&n, magnaflow, 8000k HIDS.
    Jan 2006
    SOUNDS LIKE A CLOGGED FUEL FILTER. MINE DID THAT ONCE AND THAT WAS WHAT IT WAS. THIS IS JUST MY GUESS. HAVE SOMEONE DO A SCAN ON IT TO SEE THE TROUBLE CODES.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Southern California
    can you do a scan on a 1990? i didnt think you could... I'm going to replace the fuel filter later tonight, because its been a while since its been replaced anyways. I'll let you guys know if this is the problem, otherwise I'll be back for more input! thanks
    Mar 2006
    <div class='quotetop'>QUOTE(TomTom &#064; Jun 20 2007, 03&#58;03 PM) [snapback]97316[/snapback]</div>
    can you do a scan on a 1990? i didnt think you could... I&#39;m going to replace the fuel filter later tonight, because its been a while since its been replaced anyways. I&#39;ll let you guys know if this is the problem, otherwise I&#39;ll be back for more input&#33; thanks
    be sure and check for a vaccum hose off....this will cause it to surge and run really rough, possi ly stallout
    First thing to check is the fuel pressure. I think it&#39;s supposed to be 15 lbs on the throttle body engines. Chances are most likely that your fuel pump is dying a slow agonizing death.
