Results 1 to 10 of 21
Thread: 2nd Time Conversion
    Jan 2007
    Unhappy
    I've been a member for a short time now, and I've been wanting to do this conversion for a couple years. I've noticed that there are a lot of knowledgeable people that have done this type of conversion before on the OBS trucks. And that was what I've been waiting for so now things are starting to come around.
    History: Was dads truck from the factory it was a 4.3L 5-speed. At 274,XXX miles and after a few transmissions my dad decided to convert to a V8. We pulled the V6 5-speed and built a TBI 355ci, with 700R4. After driving that past 300,XXX miles, dad decided to get something else. Thats when I inherited the truck. I drove that for a couple years and kept having trouble out of the 700R4. December 2005 was towed home from Corpus Christi, Tx with broken transmission at 387,XXX miles. Haven't drove it since. I decided it was time for more power.
    Since I've owned it: I installed Hotchkis TVS 2/4 Kit, energy suspension bushings, including cab mounts, power slot rotors, russell steel braided brake lines, upper and lower ball joints, POR-15 the frame.
    So now its time to upgrade the power train: From salvage yard 2003 iron block 6.0L out of Express Van 43,000 miles supposedly. I already have L92 heads and L76 intake, 73 Pickup 12-Bolt. Still looking for T56 transmission, possible custom built engine harness, and all the small items.
    Anyway here are some pics. More too come!!!
    Above December 2005 on Trailer
    College Station, TX
    Sounds like fun!
    Im also going from a V6 to a 6.0 (Being built)
    Good luck with the swap!!!
    That Express van got effed* up though...Yikes... Look at the intake haha...
    Jan 2006
    YOU WILL LOVE IT. THOSE ARE SOME STRONG MOTORS.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Nice.
    Nov 2006
    Dang, elbows deep into that. Very nice.
    May I recommend Nelson Performance for your harness and tune. Allen and Jonathan are so very helpfull.
    A "Thank You", to them.
    Redheartbeat has vast knowledge of what is going to happen here.
    A "Thank You" to him.
    Jon
    Jan 2007
    I called Nelson Performance on Friday. I asked them if their harness had a fly-by-wire option, and also about the LS2 injectors that are on the L76 intake . They told me that they don't have a fly-by-wire harness, nor the LS2 injector connectors. But he did tell me to check with Painless Performance, and they do have a fly-by-wire harness. Very nice people!
    I have read / printed the conversion thread on LS1 into OBS trucks. If any questions arise I will be asking!! Including the long tube headers that he made for his own ride.
    Thanx for the heads up!
    Chris
    <div class='quotetop'>QUOTE(Slo&#045;Mo&#045;Shun &#064; Apr 30 2007, 12&#58;06 AM) [snapback]91792[/snapback]</div>
    I called Nelson Performance on Friday. I asked them if their harness had a fly-by-wire option, and also about the LS2 injectors that are on the L76 intake . They told me that they don&#39;t have a fly-by-wire harness, nor the LS2 injector connectors.
    Thanx for the heads up&#33;
    Chris
    chris, might i suggest superior harness (501) 9821050.
    theyve got fly-by-wire and ls2 connectors.
    airdeano
    Nov 2005
    rock on...
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Nov 2006
    Back to the task at hand. I would also check with Speartech. I am pretty particular. All pics I have seen of Painless have not been loomed. Speartech uses nice wire loom. Not sure about the drive by wire though.
    Jan 2007
    One of the first things I noticed was that the Painless harness didn&#39;t have a loom. That does worry me, and it looks really cheap that way, although I know the price isn&#39;t. I never heard of Speartech but will definitely check into them. Thanx&#33; Any other brand names?
