If you have the stock springs with a newer LS6 cam, you may have broken one of the springs. The stock truck springs won't handle the amount of lift the LS6 cam puts out due to coil bind. You need some comp 918 or LS6 springs. On the other hand, you could have a cracked or bad rocker or just a worn rocker pedestal due to the bent pushrod. Good news is pedestals are only about $5.
Be sure to get some hardened pushrods ASAP if you're doing high RPM runs. 918s would be well advised, also. You could have a lifter bleeding down but check your exhaust gaskets first. They'll make a sound like a lifter ticking.
