Thread: Ls6 PCM
    I recently picked up an '03 LS6 from a wrecked vette. Since all Z's were 6 speeds and I would like to go auto, can I get the PCM reprogrammed to shift the 4L60e?
    TIA
    Yes, send it to Allen at NelsonPerformance and he can put an auto program in it for you. You'll probably want the VATS disabled and stuff like that too. Do you have a programming software for the PCM? If not, get Allen to turn off all the stuff you don't need and program it for your gears, tire size and remove any emissions stuff you're not going to use. I think he calls it a hot rod tune.
    Thanks Red,
    I've been told both, that it can and can't, so that's good. I'll be getting some kind of tuning program eventually, need to get it installed in the truck first!. I've got LT1 edit for my S-truck.
