Results 1 to 8 of 8
Thread: PCM mount
    Feb 2004
    What is everyone using to mount their computer? No zip ties are not an option
    My truck should be coming back from the paint shop this month sometime (been almost 5 months now) and one of the first things I need to do is get the computer tuned, and then mounted.
    '91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, '00 LS1 and 4l60e. Almost all done!
    http://s57.photobucket.com/albums/g220/98hd/Chev/
    What's wrong with zip ties?
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Feb 10 2007, 10&#58;22 PM) [snapback]82913[/snapback]</div>
    What&#39;s wrong with zip ties?
    Zip ties are your friend, but use in moderation.
    Oct 2005
    I bought a used plastic pcm box, and welded a bracket together to mount to the radiator support under the hood.
    Looks pretty much stock, no zip ties.
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
    Feb 2004
    <div class='quotetop'>QUOTE(pnhigg &#064; Feb 11 2007, 09&#58;24 AM) [snapback]82939[/snapback]</div>
    What vehicle did that pcm box come from?
    &#39;91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, &#39;00 LS1 and 4l60e. Almost all done&#33;
    Oct 2005
    I was either an &#39;01 or &#39;02 fullsize.
    It is a 2-piece cover with bolt holes that I bolted to the bracket.
    May 2003
    I&#39;m using a pcm mount from a &#39;98 to &#39;02 F-Body.
    Fits in the stock location like a glove
    Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
    New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, &#39;02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
    Feb 2004
    Thanks for the info, now for the hard part, finding a mount to buy.
