Thread: Transgo 4L60E-HD2 kit W/Separator plate & pistons
    Jun 2005
    Behind enemy lines in Kommiefornia.
    Red face
    I removed this kit from my 4L60E, as well as a new transgo separator plate and new Aluminum GM pistons.
    The transmission output shaft broke because I broke three teeth off the ring gear in the rear end. This caused the drive shaft to stop, thus snapping the output shaft.
    As I have replaced the 60E with an 80E, I no longer have use for these parts.
    They are in perfect shape. 70.00 shipped to the lower 48.
    Also, I have many good parts from the same transmission. Let me know what you need.
    Thanks.
    2000 Silverado ECSB, 5.3L, 7" CST/3" PA lift, Hanneman 'glass fenders & bedsides, Currie Dana 60 W/ Detroit Locker, 4.56:1 gears , Willwood Dynalite Pro 4 piston rear brakes, Bowtie Overdrives 4L80E, Nelson Tune & Fan Harness, Harland-Sharp 1.8 Roller Rockers, 2200RPM Converter, Mezerie electric water pump, K&N FIPK II, Dynatech Supermaxx SS LT headers & SS cats, Flowmaster American Thunder cat back, Magnecor wires, Flex-a-lite 282 monster fans, B&M Hi-Tek trans cooler . No DEathCOOL.
    And an ls1.com decal on the back window!
    I don't suppose youd ship to the 51st state?
    That which does not kill usually hurts a lot!
    The Hoe's humble beginings.
    Jun 2005
    <div class='quotetop'>QUOTE(CompToyZ &#064; Jan 5 2007, 01&#58;41 AM) [snapback]78367[/snapback]</div>
    I don&#39;t suppose youd ship to the 51st state?
    email me your zip code so I can check shipping rates
    2000 Silverado ECSB, 5.3L, 7" CST/3" PA lift, Hanneman &#39;glass fenders & bedsides, Currie Dana 60 W/ Detroit Locker, 4.56:1 gears , Willwood Dynalite Pro 4 piston rear brakes, Bowtie Overdrives 4L80E, Nelson Tune & Fan Harness, Harland-Sharp 1.8 Roller Rockers, 2200RPM Converter, Mezerie electric water pump, K&N FIPK II, Dynatech Supermaxx SS LT headers & SS cats, Flowmaster American Thunder cat back, Magnecor wires, Flex-a-lite 282 monster fans, B&M Hi-Tek trans cooler . No DEathCOOL.
    And an ls1.com decal on the back window&#33;
