Results 1 to 10 of 19
Thread: Trans Problems?
    Jan 2006
    HEY GUYS,
    MY TRANS SOMTIMES LOCKS THE CONVETER UP AT 30 MLS PER HR. THEN THE TRANNY SHIFTS HARD. I WILL PULL OVER AND TURN THE TRUCK OFF AND START IT BACK UP AND IT RUNS FINE? IT DID THIS A LONG TIME AGO AND THEN QUIT NOW IT HAS DONE IT TWICE TODAY. ANYONE KNOW WHAT IT MIGHT BE? I HOPE IT IS MINOR.
    HELP,
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Defective TPS.
    Jun 2005
    Round Rock
    Did you say it was the TPS Report??
    When I first converted this truck over to LS1 I had the same problem and that was what it was, Throttle Position Sensor took a crap. Replaced it and 10k later no problems. It may not be your truck's issue but it sure was mine.
    Jan 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Dec 6 2006, 07&#58;21 AM) [snapback]75533[/snapback]</div>
    When I first converted this truck over to LS1 I had the same problem and that was what it was, Throttle Position Sensor took a crap. Replaced it and 10k later no problems. It may not be your truck&#39;s issue but it sure was mine.
    Thanks, Red
    I have an extra one. I will take it to Allens when we do the converter swap. Or can I put it in with out calibrating it?
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    no calibration required. bolt it in, turn on the key, run the throttle slowly from full close to full open about 4 times and all is good. Turn off and start truck.
    Apr 2003
    Allen, Tx(DFW)
    <div class='quotetop'>QUOTE(jethro_3 &#064; Dec 5 2006, 09&#58;58 PM) [snapback]75521[/snapback]</div>
    02 Silverado
    02 TrailBlazer
    Apr 2005
    Ummmm, yeah......
    Gone, but not forgotten!
    Jun 2006
    Before Installing any Sensor, some say is wise to diconect the negative terminarl from the battery.
    Just a minor precaution wont hurt anybody...will it?
    Need a Freakin&#39; Roll Cage, and a Death Insurance
    Jan 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Dec 6 2006, 07&#58;29 AM) [snapback]75535[/snapback]</div>
    I can handle that.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
