looking for a golf cart in TX. Prefer electric, less than 5 yrs old. Apparently you can beef these things up to run 30 mph with just a few hundred bucks.
2013 2wd Z71 6.2 crew cab
Golf cart? I want to see some numbers from the fodo. Is the transmission bulletproof yet?
<div class='quotetop'>QUOTE(stssilverado @ Oct 29 2006, 08:59 PM) [snapback]71582[/snapback]</div>got a gas powered one here in waco, BUT im holding on to it. were aiming at hitting around 40 with it in the next few years. right now it tops out at 18mph.looking for a golf cart in TX. Prefer electric, less than 5 yrs old. Apparently you can beef these things up to run 30 mph with just a few hundred bucks.
most of them go 12-13 stock. 40 in a gasser is attainable with the right gearing.
why on earth would you want to beef up a golf cart. Do you want to piss off the golfers by doing a burn out down the cart path. <--"Actually that would be funny"> Go for it. I want to see pics of the golfs throwing there clubs when you do that.
2004 EXC Silverado 6.2L
Mods:
Ever ridden in a cart that fast? It is scarry as hell!
the answer is yes. piss off everyone is the idea.
I got my ridin Lawn Mower to hit 30mph just from exaust and changin the pulleys around.
It hauls![]()
Good luck with the golfcart.
01 RCSB, 5.3, TR224/112
4.10 w/ Auburn
3200 Fuddle, HD2, Vette Servo
Nelson Tune, LT Headers
<div class='quotetop'>QUOTE(stssilverado @ Oct 30 2006, 08:22 AM) [snapback]71624[/snapback]</div>well, about a year ago we got the truck beside it and it showed 18mph on the speedo. thats stick too, need to get it fired back up and switch some gears around.most of them go 12-13 stock. 40 in a gasser is attainable with the right gearing.
[/b]![]()
<div class='quotetop'>QUOTE(Allstar55566 @ Oct 30 2006, 03:11 PM) [snapback]71665[/snapback]</div>i have this one for sale... it goes 20mph and climbs stairs...well, about a year ago we got the truck beside it and it showed 18mph on the speedo. thats stick too, need to get it fired back up and switch some gears around.
