Hey guys just like some help my dad has a old 350 sitting in his shop and would lke to know if it would be a good idea or should i envest in a ls1? some feed back please thanks smoke 118.![]()
http://i107.photobucket.com/albums/m...smoke118-1.jpg
2001 GMC Z71 with 4.3L V6 flowmaster mufflers and intake spacer with a K&N cold air intake and a super coil along with under drive pullys and mudd terrian tires
<div class='quotetop'>QUOTE(smoke118 @ Nov 5 2006, 04:03 PM) [snapback]72298[/snapback]</div>how old is it? is it stock... more info on the 350 would be needed, but isn't the ls1 technically a 350??? i figure most r gonna tell u the ls1 is gonna have the biggest aftermarket of any engine ever made, but idk depends on what all the 350 has done to it already.Hey guys just like some help my dad has a old 350 sitting in his shop and would lke to know if it would be a good idea or should i envest in a ls1? some feed back please thanks smoke 118.
[/b]![]()
<div class='quotetop'>QUOTE(Allstar55566 @ Nov 5 2006, 04:11 PM) [snapback]72300[/snapback]</div>Well the 350 is stock and is out of a 72 chevy pickup and no a ls1 is not a 350 a 350 is a 5.7L. no work has been done to the motor but if i do get it i will bore out the pistons about .40 over and after market injection.how old is it? is it stock... more info on the 350 would be needed, but isn't the ls1 technically a 350??? i figure most r gonna tell u the ls1 is gonna have the biggest aftermarket of any engine ever made, but idk depends on what all the 350 has done to it already.
[/b]![]()
An LS1 is a 5.7 L and 350
General Specifications
Displacement 5.7L (5665cc, 346ci) Gross Horsepower 310 @ 5200 RPM, 320 @ 5800 RPM
Bore/Stroke 3.90/3.62 Gross Torque 340 @ 4000 RPM, 330 @ 4400 RPM
Compression Ratio
10.1:1 Maximum RPM
6200
Firing Order
1-8-7-2-6-5-4-3 Out of crate weight.
Approximately 390 lbs.
Spark Plug
ACDelco 12
ACDelco 41-985 Spark Plug Gap
.060”, 1.524 mm
Block Specifications
Block Material
319-T5 Aluminum Block Description
90° V, Deep skirt with cast-in iron sleeves.
Bore Spacing
4.40” Deck Height
9.24”
Main Bearings
5 Thurst Bearing
Center Bulkhead
Bearing Caps
4 vertical bolts, 2 cross bolts
What are you wanting to put it into? Some engine swaps are just totally illegal in anything but an 100% offroad vehicle.
<div class='quotetop'>QUOTE(smoke118 @ Nov 5 2006, 04:18 PM) [snapback]72302[/snapback]</div>dude ive got a 72 chevy truck in my driveway, and my 4.3 v6 seemed much more powerful than the 350. ur looking at upgrading a few things on the 350 if u wanna make it nice. the ls1 would be ready to blow and go stock. 350 is a great motor, but the ls1(350) is far advanced as far as efficiency and power goes.Well the 350 is stock and is out of a 72 chevy pickup and no a ls1 is not a 350 a 350 is a 5.7L. no work has been done to the motor but if i do get it i will bore out the pistons about .40 over and after market injection.
cool thanks for the info just one thing i was told that droping a ls1 would be easy than a 350 well i guess i will start looking for a ls1 then.
<div class='quotetop'>QUOTE(RedHeartbeat @ Nov 5 2006, 04:49 PM) [snapback]72306[/snapback]</div>my every day driver looking to get rid of my 4.3l looking for more power and mpg on the highway.What are you wanting to put it into? Some engine swaps are just totally illegal in anything but an 100% offroad vehicle.
