Results 1 to 10 of 13
Thread: 4.3 to 6.0
    College Station, TX
    I found a 6.0 with a tranny for 1850. Comp, intake, headers included
    How much will labor run you guys think?
    also what other parts will I need?
    v8 harness
    engine mounts
    what else? can you guys help me out?
    do I need the rear end now?
    the 6.0 is more of an animal than the 5.3 i went with if you can get the computer all wiring and the distribution box ie: fuse box as the 6.0 wont match to the 4.3 box... get the mounts also which i doubt these will work niether.. for a 5.3 i had to use on the passenger side the 4.3 and driver side the 5.3 mounts, fit perfect...as for rearend i would upgrade as the 4.3 probably has a 323 gear ratio .... get verything posible you can the more the easier ...
    Simple: 408 on steroids!
    single digits coming soon!
    Jan 2006
    <div class='quotetop'>QUOTE(Aggie &#064; Feb 20 2007, 07&#58;45 PM) [snapback]83978[/snapback]</div>
    v8 harness
    engine mounts
    WHOSE BUYING IT YOU OR SHWARMY?
    ITS A GOOD DEAL IF THE MOTOR HAS LOW MILES ON IT. YOU NEED A CROSS MEMBER IF YOU USE THE TRANS, DIFFERENT DRIVE SHAFT I THINK? HARNESS, LABOR I DON&#39;T KNOW? GIVE ALLEN A SHOUT HE WILL KNOW AND CAN TELL YOU WHAT ALL YOU NEED TO GET THAT SUCKER IN YOUR TRUCK.
    JAMES
    12 Sec. Club! SOLD
    SOLD***
    College Station, TX
    *Hey Allen?* haha
    Yea Im buying it thats why Im selling my bike for 4600 lol
    I know it includes the computer I dont know about the distribution box. And Im going to upgrade the gears to 373. But if you guys can a list of needed equipment would be great
    So heres the new version:
    -V8 harness
    - Engine Motor mounts
    - Distribution box (If it doesnt come with it, not sure yet)
    College Station, TX
    Ive got another question..
    Can I just get the 6.0 with computer, harness, mounts, intake, exhaust, and leave the 4l60 and 323 rear end?
    I will upgrade the rear end later...is it possible?
    Labor is about 50 hours according to Street and Performance plus parts.
    College Station, TX
    what just swapping engines? hmm....
    If you were swapping V8 to V8 Gen3 to Gen3 it&#39;s not so bad but you&#39;re converting a whole lot of stuff that isn&#39;t just a straight swap when you go from a V6 to a V8. Wiring is different, exhaust, mounts, tons of stuff. Ask guys on here that have done the conversion, it&#39;s not so bad but it is very time consuming.
    College Station, TX
    yea..I was gonna get allen to do it...anyone here got him to do it?
    Jan 2007
    Louisiana
    V6 trannys wouldnt bolt up to a 6.0, needs another torque converter, and an input ... even with the v6 tranny all beefed up wont last long with the 6.0...
