<div class='quotetop'>QUOTE(chrisj6 @ Sep 26 2006, 07:09 AM) [snapback]66633[/snapback]</div>
I could be wrong but isnt there a seperate fuse for the injectors, I thought I remembered seeing something one time for them in the fuse box but I could be wrong.
Chris
There are two fuses one for each bank of injectors. The injectors should have power + when the key is on. The PCM pulses the ground. You can use a test light (they sell noid lights at the autoparts) to check for injector pulse.
