Thread: 1/4 - 14.658@93.3mph in 105 degrees @ Ennis, TX
    Apr 2005
    So that's what I did with a 60' of 2.3 in overdrive w/ an 1/8th mile of 9.43@77.46mph. I was really bummed about it. So much so, I actually deleted my own post and modified my Signature.
    Last night with 88 degree temps we went to the same track and 05/06 Mustang GTs were running somewhere between 14.3 and 14.8 timeslips.
    Tonight I met up with a Mustang (have seen on the web and in some of the mags that these do 1/4mile in 13.5 - 13.9 (the very ones which were running 14.3/14.8 ETs last night at Ennis.
    With half-a-tank of gas, a 180lb passenger, on practically bald 275/60/15 BF Goodrich Radial T/A tires on the rear, with the windows rolled down on the truck. We took off and held right with him until 90mph where I was at his bumper and he got to about a half a length in front of me before he let off. I really was impressed with my auto tranny. It helped me a lot, he was obviously not good with his 2nd to 3rd shift cause I would gain quite a bit on him when we can onto this.
    So there's my story and I'm stickin' to it and happy to be judged by it. I'm going to work on weight reductions and see what I can come up with besides working with the pre-intake, E-Fans (removing the clutch fan and eventually swapping out the wheels for something lighter.
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    we still love you. whether your dissapointed with the time or not, your truck is still damn fast.
    Any time you're beating Mustangs in a fullsize GM truck you're doing great. A 1500 or so pound handicap makes a world of difference. The mustang guys up at Denton Dragway have learned to stay away from my old truck, they lost religiously unless they had help from a blower. Put the truck on a diet and get a little spray to help things out. Even a spray of CO2 will help cool the intake charge down to help make more power. A 100 shot of nitrous would send them home crying, too. Just be sure to have it set up properly so you don't pull a greg and hole a piston. Lean or ping is bad and leads to a rebuild.
