Results 1 to 10 of 10
Thread: 323 to 402?
    Jun 2006
    Hi again
    Is there any way I can push a 5.3L to become a 402 ?
    Happens that I have a spare one coming next month. But wat to try something cool with it?
    Any suggestions?
    Need a Freakin' Roll Cage, and a Death Insurance
    Yeah, buy one of TRTTurbos blocks and a 4" stroker kit with pistons. Use all your parts to swap over.
    Jun 2006
    I was looking more to push the block, like a crank will be the heaviest thing to order!!!!!
    Any other way for not buying a block?
    The machine work will be more expensive than buying a new block if you have it machined correctly.
    Jun 2006
    Not actually.
    I can have a very low cost machine work done here.
    If you give me the measures and the pistons and crank to go with it I can do it.
    Will the 5.3L stand for it?
    To put things here on mail orders cost me 5 bucks per Lbs+volume, so imagine the block cost delivered.
    That's the main reason I dont have a 400SB on my camaro. just a 5.7L bored to the max
    Dec 2003
    Newark, Tx.
    The 5.3 block might be able to take the bore, but it wouldnt be safe.
    To get to the 402, you need a 4" stroke and 4" bore. You can make a hell of a 383 though.
    Aug 2005
    Spring, Texas
    <div class='quotetop'>QUOTE(trtturbo &#064; Aug 13 2006, 09&#58;49 PM) [snapback]61113[/snapback]</div>
    Do you uys know a round about price that it would take to build a 402?
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Dec 2003
    Newark, Tx.
    <div class='quotetop'>QUOTE(bulldog5.3 &#064; Aug 13 2006, 10&#58;57 PM) [snapback]61117[/snapback]</div>
    I&#39;m getting a price for Red and I&#39;ll post it up for anyone else.
    It will be starting with a new 6.0 block, Eagle crank and rods with ARP rod bolts, more than likely Wiseco pistons, & Childs and Albert rings. I just need to verify a few prices with my builder.
    Pistons could change depending on what you want. Some of the off the shelf Wiseco&#39;s will raise compression too much or if its for a turbo, make the compression too low. Heads have to be picked accordingly.
    Dec 2003
    Newark, Tx.
    Okay,
    This is for a 408ci;
    New 6.0 block, Eagle 4340 forged 4" crank, 6.125 Eagle rods with ARP rod bolts, Wiseco pistons 4.030 bore, Childs & Albert rings, Federal Mogal and Clevite bearings, ARP main studs.
    LIne bored, cylinders bored and honed, rotating assembly balanced, decks checked, file fit rings, and assembled.
    &#036;3600.00
    Lead time is 2-3 weeks. Lunati crank available. Depending on your heads, JE or Diamond pistons may be substituted for the Wiseco.
    Apr 2003
    Mansfield, Texas, USA
    Just build a 6.0 block, it already has the 4" bore. Going well over .125" over is going to get into some serious cylinder thickness issues (think overheating, distortion, etc).
    I heard that Wiseco and JE were made by the same company... if so, I wouldn&#39;t want JEs. I have seen a few sets crap out. Diamond or Ross are nice. I&#39;m going to use Venolias.
