Thread: 2nd Accumulator Piston
    Jun 2005
    where is it located? Valve body or somewhere more internal? Billy and I were talking last night about the Transgo install and neither of us could recall anything like this.
    '02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
    There are two of them. One is in the valve body, the other is in it's own little casting bolted beside the VB.
    Jul 2006
    College Station, TX
    I recommend replacing all accumulator pistons when you do this to metal ones. there are 3 accumulator pistons and 1 of them is made of cheap plastic.
    2004 EXC Silverado 6.2L
    Mods:
    Jun 2005
    Yeah....cheap #^&*$J*NRF^&E%^@&(@%&* breaking plastic!!!! No plastic after the rebuild though!
    Yeah, forgot about the other one.
    Dec 2003
    Newark, Tx.
    Its the on by the valve body. A 2nd spring was added from the shift kit, but no upgraded metal piston.
