Results 1 to 10 of 17
Thread: stock stereo
    my buddys got a 2000 z71, and he was changing the oil in his truck, he reset the engine oil light. left it alone. came back an hour later and now his stereo isnt working. he said "i turn the truck on and the screen stays black until i hit the clock button, then the clock comes up for like 20 seconds then goes off again, but i can't turn it on." he has an after market system hooked up to his stock stereo. so hooked up to the stereo, is the rca cables, and the remote wire. its wierd. any suggestions on what the problem might be?
    Sounds like the anti-theft module has been activated.
    Dec 2005
    Dallas, TX
    yup!!!!
    2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
    9.5 in the 8 mile
    6000K xrtalight h.i.d kit
    well i asked him the same thing. and he has the code for it, and hes had to reset it before, so he said it wasnt htat when i asked. so i dunno
    Jun 2005
    ducky is it a stock stereo he had or that he picked up seperatly and why is he using a aftermarket harness? The clock power is seperate from the stereo power and he may have blown a fuse to the radio power. Dunno
    01,Z71 Victory Red, sportside,5.3L, Flowmaster 40's, K&N Drop In, Airaid MIT Tube, TB bypass, Nelson Performance Hot Tune. Velocity Stack waste of money.
    Working to run with the BIG DOGS, tired of the porch. STS or LQ9 in the future.
    http://i56.photobucket.com/albums/g1...1/DSC02262.jpg
    <div class='quotetop'>QUOTE(NalgonaZ71 &#064; May 3 2006, 08&#58;26 PM) [snapback]52027[/snapback]</div>
    its the stereo that came with the truck. he just has subs connected to his stock stereo, thats why i said hes got rca cables and a remote wire running from the amp to the stock stereo
    Jun 2005
    then I would check for a loose connection, blown fuse, bad ground, but it does sound like the anti theft protection has activated. Not sure why it did not reset when he input the code. But like I mentioned the stereo power is seperate from the clock.
    01,Z71 Victory Red, sportside,5.3L, Flowmaster 40&#39;s, K&N Drop In, Airaid MIT Tube, TB bypass, Nelson Performance Hot Tune. Velocity Stack waste of money.
    <div class='quotetop'>QUOTE(NalgonaZ71 &#064; May 3 2006, 09&#58;45 PM) [snapback]52043[/snapback]</div>
    where is that power source located? just in the fuse box? because my buddy said the fuse isnt blow for the stereo, and then he said "the CD and tape players both have power to them but i can&#39;t turn the stereo on". there wouldnt be a short of any kind would there?
    Jun 2005
    don&#39;t think its a short the deck may have a problem The same power that feed the CD and tape is for the deck. The deck may be DOA
    yeah i think his stereo just went out plain and simple. since i have an aftermarket stereo in mine, he can swap out my stock stereo out my truck, into his right?
