Results 1 to 5 of 5
Thread: Vortec 4.8 Crank swap and re Bore to Make LS1?
    Mar 2006
    I currently have an 06 SCSB with the 4.8 running a 100 shot ColdFusion wet kit. I have been kicking around the idea of swapping out the crank to make it a 5.3, but after reading some other posts I am thinking I can swap the crank and bore it out to make an LS1. Has anyone here done this before? Making it a 5.3 seems fairly simple and with the iron block I am thinking it should be able to handle the bore to LS1 specs. Am I missing something or will this work? The current setup runs good on spray but it is pretty lazy on motor alone. I appreciate any help that can be offered.
    Feb 2005
    Bore out the block and toss in the rotating assembly from a LS1.
    New Truck on it's way: '07 Classic GMC 2500HD DuraMax LBZ
    03' Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99' Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02' PCM, LT1 fans
    I don't have my reference books here in front of me but I believe the crank is the same in the 4.8/5.3/6.0/5.7 gen3 engines, all have the same stroke just different bores.
    Oh, forgot, the 99-2000 6.0L have a thicker flange on the crankshaft than all the others. Uses old style transmission/flywheel.
    Mar 2006
    Dawson Springs KY
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Mar 1 2006, 03&#58;10 PM) [snapback]45725[/snapback]</div>
    I don&#39;t have my reference books here in front of me but I believe the crank is the same in the 4.8/5.3/6.0/5.7 gen3 engines, all have the same stroke just different bores.
    To my knowledge that is correct.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    San Marcos Texas
    Quality machine work and parts are expensive for the LSX engines. IMO get a 6L longblock and swap it out.
