Thread: WARNING
    Apr 2005
    You guys can see the setup below. Had read on the web (after-the-fact) that someone had read Powertraxx doesn't do well around 400hp. Well, I think I can put that theory to rest.
    I had thought the problem this whole time was with the driveshaft/carrier bearing/axle. Well...guess what remained intact, but ruined the ring-pinion? It broke off two teeth, then skipped a few and broke one more off. Apparently one got thrown into the heavy duty differential cover I had and cracked it all the way through
    So, what do I replace it with - Auburn or Eaton? Another?
    I'm going back with the 3.73s and the posi and a new heavy duty cover.
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    Feb 2005
    Austin, Texas
    detroit trutrac
    North Georgia
    [/quote]
    Eaton 800# unit and a Moser cover with the bolts that brace the carrier here.moser cover
    The Corvette inspired Silverado is now rolling strong!
    http://www.ls1truck.com/forums/lsx-t...silverado.html
