Results 1 to 8 of 8
Thread: Tires?
    Nov 2005
    Six of one, half dozen of another but tires would you put on a 2002 Silverado 4x4 with a 4.8? I am looking at Bridgestone Deuller 265 75 R 16's. Any other suggestions? I do not offroad at all and use the truck to tow my Ranger Fisherman which is about 2000lbs.
    I think you're going to have to look at a different size. 4x4s haven't had 15" tires since the early 80s if I remember correctly.
    You should have 245-75-16 Having said that it really depends on what your going to use them for and climate. IMO Mich LTX M/S is an awsome tire for tread wear and comfort but is very expensive. You will not beable to get out of your own parking spot in the snow or sand either, expect to pay about $150. You could save a few bucks and go with the BFG Long Trail T/A it is also a MAST product and is owned by Michelin and is comp to the LTX about $110 a tire. The best bang for the buck I think is the Yokohama GeoLanders there only about $87. I have seen nothing but praise in the last 2 years from the Yokohamas. These are the best 3 OE replacement tires I think. Also keep your eye on Sumitomo they have slowly became the the 3rd largest tire company? Though I dont have any feedback on them yet.
    Oct 2005
    I guess a lot would also depend on if you are going for a particular look with your truck. Mine never will go offroading, but I like the look so I'm running some agressive tires on mine. Are you just wanting a good street tire, the offroad look, allterrain? Any additional input?
    2002 Chevy Silverado Z71
    Alpine DVA-7996, PXA-H700, KCA-420i
    Audison LRx 1x400 and 3 1x250
    Focal Beryllium Tweeters and 8" Sub, Focal Utopia 7" Midrange, 2x Focal Access 40A 16" Sub
    K&N Air Filter, Flowmaster Exhaust, Hypertech Programmer III, 20" Boss 309 on Nitto Mud Grappler 33x12.50R20
    Nov 2005
    Great replies...I thank you guys for your input. My truck does a tad bit of towing...my bass boat....and NO off-roading. Never will.
    I was checking up these Sumitomo tires....6 year warranty?
    Nov 2004
    Check into the Nitto Terra Grappler AT's, smooth ride, good looks, and price is decent.
    01 CHEVY 2500HD 4X4 ECSB, K&N, Pacesetter LT'S, 4.10 GEARS, 4L80E, 285/75/16 NITTO TERRA GRAPPLER AT'S , ALPINE CD PLAYER, 2 MTX 10'' SUBS CUSTOM ENCLOSURE, MTX 800 WATT AMP. NELSON TUNE, ASP PULLEYS, AND 05 E-FANS, Flo-Pro HD MUFFLER, LS6 PCV CONVERSION.
    Oct 2005
    Warsaw, Va
    I was looking at them, but they didnt come with white letters...
    I opted for the 285 M/T radials and those are cheap tires for having the M/T name
    ride is great and and are a nice A/T type of tire
    04 ECSB Silverado 4X4
    Nelson Tuned - 220cam - 3000yank stall - stage 1 heads
    LS1 fans - ASP pulley - 3inch lift - ASM LT headers Mod Page
    aka 98TAauto - 98TA 11.4 @ 119 H/C street trim
    Nov 2005
    ohio
    BF GOODRICH ALL TERRAINS ALL THE WAY!,great ride no sidewall flex,no noise long life ,ive had 6 sets over the years, great traction on /off road, 1 set i had got 80,000miles lots of rotating, but still good life, if you a slightly beefy look get 285 /75 /16 , ive got 265 75 17 ,i wish id went 1 size bigger.good luck
