Man got a problem that I hope someone can help me with here , I bought a set of fans off E-bay , it came with a harness from Nelson Performance , I hooked up the harness as per pics and instructions but the fans do not operate as they should , with A/C on only one fan runs (driver side) and with A/C off both fans run but at a very slow speed , so what did I do wrong ? I was a little confused on which wire to connect to in the wiring loom , it said solid green wire but their are two green wires one is a dark green and the other is a light green , I connected to the dark green wire, I used a ohm meter to test the connection and have 12v at the connection when A/C is on and 0.0 when off. I tested both fans and they both work when 12v is supplied to either one , I had pin 42 activated and am connected to that with the PCM.
Anyone got any ideas.
