Broken Manifold bolt.............. Suggestions...........
My friend and I were prepping my engine and installing a new oil pan.. he noticed the driver side rear manifold bolt was broken and there were signs that both sides had leaking manifold gaskets... luckily the rest of them came out with no issue... the one that is broken is broke off almost flush with the head.. Any suggestions on the easiest way to fix without removing the head and taking it to a machine shop...
Also should I go back with OEM bolts or something different... this seems to be a problem with the stock stuff... I will be re using my stock manifolds
- You may not post replies
- You may not edit your posts
