I would like to know what would be the best way to attain 450-500 fwhp from my 05 silverado with a Turbo setup
Bolt it on and crank the boost up.
Nelson Performance front mount 76/96 on a mostly stock engine with about 10-12lbs should net you well over that. My cammed 5.3 with 12lbs makes 554/557
What's the best way to tune for a Turbo and what mods would I need minus a cam and springs and gaoling top ring
And I have read the stock trans doesn't like the power to well what is ur suggestion on this and what size stall would be best
Stall depends on your can but usually a 3200 if your boost comes in low. I've been thru 6 trans with my set up, one 4l60 four 4l80's and a 700r4 that I slipped the clutches in Wednesday. Got a th400 in the works. If I had it to do over I would have built the trans before I built the turbo kit.
What all is needed to convert to a Turbo 400 BC I have a full race built 400 with Kevlar clutches and all the works in my c10
I would say, valve springs, pushrods, tune (nelson does the tuning) and then a strong trans for anything 5-7lbs or more. The stock trans wont last long at all. I had a fully built one when I had my first turbo, so I didn't worry about blowing the trans at all.
Is it best to do a cam when u do everything else
