Results 1 to 7 of 7
Thread: vacuum leak at master cylinder
    Feb 2011
    Sevierville, TN
    I've noticed a hissing sound coming from the engine compartment of my 05 GMC CCSB for a while. I finally tracked it down to a vacuum leak from the brake booster where the master cylinder bolts to it. Is ther some sort of gasket or seal there? Would the booster be bad? Is there a cheap fix for this?
    Matt
    Thanks to all American soldiers for their service and sacrifices.
    Pittsburgh, PA
    mine did this, i replaced it with a larger 06 setup
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Feb 2011
    Sevierville, TN
    So is my booster bad?
    Matt
    I actually replaced a brake booster on an 02 Envoy, because It rusted through right underneath the master cylinder in a small pinhole. I had bought a replacement master cylinder, because that's what I thought it was but it wasn't. Mine didn't have a seal between the two, good luck!!
    O ring between the master cylinder and booster.
    Feb 2011
    Sevierville, TN
    Got a part number? I called the local GM dealer and it doesn't show an o-ring or gasket.
    Matt
    Nope. My 2007 gmt900 shows to have one but i do not have the pn.
