OK so I have a wire coming from my ecm thats supposed to hookup to my brake switch. Easy right? Well the wire needs power all the time and ground when the brake pedal is pressed. I only have a two wire switch. Power and ground. The ground has power when pedal is pressed. So I dunno what to do with the wire cause there's not anywhere to really hook it up. Anyone got any suggestions or parts to fix this issue? Thank!
