Results 1 to 10 of 19
Thread: Cant find the wires for dash
    a place where it snows 6 months a year
    I have got almost all the wiring complete and am looking for the oil pressure gauge wiring and the water temp gauge wiring. i just need to know what connectors and pins they are. other then that swap is mostly done. got all the parts and now just need the motivation...
    can someone help with the locationsof the 2 wires i am looking for?
    1997 ECSB Chevy 1500 2WD, Lowered, tinted, 17" Impala wheels. True duals dumped w/ no cats. Ford 9" with LS1 F-body Brakes. Hipster (ATD) 4l60E. 3000 Stall.
    My Garage -----> http://www.ls1truck.com/forums/my-ga...tml#post252565
    harness is completely done but has 3 wires hanging out now, SES light, temp and oil sender wires. HELP please!?!?!
    you need to know which wires come from the truck and hook to the senders? My 92 and both 93s I've done, the wires come from the firewall block on the driver side between the brake booster and the fender.
    ya i need the truck end. i kinda figured that but someone went happy go lucky with the side cutters and removed alot of wiring and i have a pinout of the connector for a 99 and it is a little different. i am looking for the pin numbers in that connector. thanks
    Sorry, I don't have the dash harness info in my manual for the newer trucks, only up to 94.
    Nov 2009
    Fort Smith, Arkansas
    The newer ones have firewall connectors? That's a new one on me.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    Oct 2003
    O.K., here goes...The main "C-100" firewall connector, on the drivers side firewall, consists of an arrangement of wire "cavity" wires coming out of it. This arrangement is more or less in a square pattern, with many wires exiting. From top to bottom, the first row across, from left to right, are the "A" wires(or cavities). The second row across are the "B" wires. Third row are the "C's", fourth row "D's", & fifth row are the "E's". In row C(third row down), the 4th wire across(C4) is a tan wire labeled "oil pressure indicator lamp output". The very next wire, next to it(C5), is dark green & is labeled "coolant temperature indicator lamp output". Its been years, but I think these are the wire outputs I used. This is from a 1996 GM Manuel. '96, '97 & '98 were transition years for our trucks with regards to wiring & some other things, but were very simular. As you might know, '96 was the first year of OBDll, on-board diagnostics, second generation. But your '97 should be the same as my '96. Hope this helps.
    perfect...that is what i was looking for.
    C4 - oil pressure
    C5 - cooant temp
    by chance would you know what the ses light pin number is?
    that should be a wire that used to go to the old PCM. Was that removed before you got the truck?
    like i said someone went crazy with the side cutters on that plug. thats why i was looking for the pin numbers so i can re-add them to the plug.
