Looking for a set of unmolested good condition 862 or 706 heads. Main reason for the need is fixing the exhaust leak from broken bolt during long tube install. Yes I already tried an extractor...got the other 2 bolts out...but it destroyed one bolt and ruined the hole. Only options I have are replace the heads, I'll probably have them milled and cleaned up, or drill a larger hole, re tap it and go through that bs which I don't want to deal with so swapping heads is ultimately easier.
