Hey everyone. I haven't posted on this site in a while. Hope everyone's well.
So let me give you some history on this truck. 2002 1500 Silverado, supercharged 4.8ltr V8 w/ injectors out of a 6.0ltr truck (recommended for supercharger). Supercharger blew piston rings on two pistons after about 35k miles of usage.
Now for the swap. I swapped in a 5.3ltr engine w/ trans out of a 2003 Avalanche. The Avalanche 5.3 went in complete with it's original intake manifold. The parts transferred over from the 4.8 were throttle body (cable type, to eliminated drive by wire), alternator, ac compressor (kept to avoid disconnecting freon lines), fuel rail w/ 6.0ltr injectors (needed the original fuel rail w/ fuel return line), and fuel pressure sending unit (located on top of the block behind intake manifold. Did this to keep compatibility with 4.8's original wiring harness), headers w/ new gaskets, and 4.8 computer (temporarily running with 4.8 tune, but plan to reflash with 5.3 tune). The only modification I had to make was running a new vacuum line to the fuel pressure regulator on the fuel rail. The 5.3's intake manifold didn't have vacuum adapter needed so I had to run a vacuum line to the other side of the intake manifold.
The truck starts easily, throttle responds very well, truck drives great, and engine sounds overall very healthy. The problem is that when the engine starts, from being cold, it idles @ 1k RPM for a few seconds and then shoots up to approx. 2600 RPM and stays there. The butterfly, in the throttle body, is completely shut, MAS is intact and connected, coolant lines are purged, no vacuum leaks, engine does not show 'Check Engine' light, and the engine runs for 10 min plus and doesn't overheat. However, the problem persists. The only thing I can think of is that I'm using the 4.8's computer, which BTW has a tune for the supercharger. It was suggested to me that I need to install the original 5.3 injectors instead of the 6.0 injectors. I was told this might be shooting too much fuel into the system, but I don't think I agree.
I would appreciate anyone's input. Thanks in advance for any help.
