Results 1 to 2 of 2
Thread: Suspension checkup
    So, when was the last time YOU checked your nuts and bolts on your suspension? I did a 4/6 drop a short while back and tightened everything good and the next week retightened again. I went out tonight and threw a wrench to the spring ubolts and I got about 3 full turns at all four corners. I would highly recommend you check yours too if you have had the factory ubolts off anytime in the past. Thank God the nuts they send in a Belltech kit have nylon locks on them or else they probably would have backed all the way off.
    Sep 2004
    Good Call! I check mine annually, and seem to be able to get at least 1/2 turn out of alot of them.
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
