Results 1 to 10 of 16
Thread: 03' and up tailights?
    Jan 2010
    rohnert park,ca
    hi i just say a 99' -02' truck the other day with 03' and up tailights is there any wiring that needs to be done or anything are they just plug in and go thats it? this may be a kind of a dumb question but thought i would ask and i was curious thanks !
    2000 chevy ecsb 2wd 4.8 - stock for now
    1969 chevy 1/2 ton short fleet 383 , m21 , 3.73's
    1987 chevy v10 350 , 700r4 , np208
    1995 nissan d21 SAS'd 3.0 D44's lockrite 4.88's 35's
    Paris, Texas
    if you get the tail lamps and harness' they will plug right in.
    Wichita Falls, TX
    ....otherwise it takes some finagling
    Paris, Texas
    yea cutting and splicing is over-rated
    Wichita Falls, TX
    The only thing I had to splice was the little lights in the corners, I didn't cut anything. I am about to wire the tails up so that all 3 lights work as turn/run/brake, maybe then more people around this turd-hole town will see me turning. It's easy when you used to be a car stereo dude.
    Nov 2009
    chicago, il
    Quote Originally Posted by lo-lyf View Post
    Do a write up, I want to do the same!
    Jan 2010
    rohnert park,ca
    ya thanks guys for the info i like the look of the 03 an up tailights
    Wichita Falls, TX
    Quote Originally Posted by truckinL33 View Post
    I will.......once I get off my keester and do it.
    I've had some driveline trouble this past week so it may be a while. Plus, it's colder than balls here and I HATE cold.
    that sounds like a cool little project you will be noticed. and as far as lights go it should be plug and play with the harness.
    i am thinking about doing this same mod to my 01
