Results 1 to 10 of 11
Thread: does anyone know how much this stock wheels weight??
    Feb 2008
    Arizona
    the thing is Im planning on buying aftermarket wheels, and i want to know if they will be much heavier than stock wheels? I dont want to loose performance.. thats my concern..
    This are the stock wheels that im talking about..
    http://elclasificado.com/ae/aeimages...l_445054_1.jpg
    This are the ones I like for my truck..
    Dick Cepek DC-1 Aluminum Wheel 17x9 6x5.5:eBay Motors (item 390077774263 end time Sep-02-09 16:13:54 PDT)
    What do you think of the wheels?
    Im running BfGoodrich mudterrains Km2's 32"
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Feb 2008
    Arizona
    the aftermarket wheels weight 24lbs..
    Jan 2005
    Humble/Houston TX
    your running 32" mud tires and worried about the weight of your wheel?
    old mod list: H/C/I/N/E/G 408
    Round Rock, TX
    Feb 2008
    Arizona
    They are 285/70R17 they are not that big, I know they are not good at all for street racing, but MOST of my races are sand races, that's why I'm running mudders.. I want to buy a good set of street tires to have them mounted on my stock wheels for whenever I go street or 1/4 of mile racing..
    Those stock 17" GM wheels weight about 45-50 lbs each. Those DC-1 wheels will help out by saving you about 160 lbs of rotating mass. The wheels only have a 4.5" backspacing...I would have expected them to have at least 5.5".
    Feb 2008
    Arizona
    is that bad??
    Not really. Its just that people usually put larger size tires on those wheels that might rub the wheel wells or frame when turning hard to the left or right. But I guess it all depends on the exact tire on a certain truck.
    Feb 2008
    Arizona
    Thanks man!! I will buy them!
    GA
    if the stock wheels weigh that much i cant imagine what my 20s weighed each since they felt a night and day difference.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
