Thread: F-Body water pump
    SOMO
    F-Body water pump
    I was wanting to know if you can run an F-Body water pump on an LQ4 without having to change out all of the other accessories and the crank pulley?
    Yes, just need a waterpump spacer and longer bolts. I have a guy that sells the spacers for $75 if you're interested.
    SOMO
    How thick are the spacers?
    do they come with new bolts?
    Also what type of metal are they made of?
    .750" thick, made of aluminum, and we can get you the bolts if you prefer for another $10. You will also need an additional set of waterpump gaskets.
    The grade of aluminum is either 6061 or 7075.
