Ouch! Hate it when that happens.
Going to try some stuff in the morning...here's hoping.
wrong size socket? Sears has those easy out type sockets for rounded off heads. An impact is usually best to break bolts loose.
Only use a 6 point socket on those, no 12 point sockets.
That can be a tough one. How long have those bolts been in there? You could, as a last resort, if nothing else works, drill a pilot hole in the center of it, then step up drill bits until you've removed the head of the bolt. I'd probably try an assortment of 6 and 12 point sockets(driving them on with a hammer), then resort to welding a bolt onto it, then drilling last.
Why are you removing the head, just out of curiosity?
I didn't offer any solutions.... you didn't really ask. I've used the Sears sockets Red mentions. They work well. I've also welded another nut to a couple and that worked.
That's all good advice. It will come out, just needs a little extra effort. Don't give up.
Seems like once I get frustrated with a situation, things go from bad to worse. I'm usually better off to walk away from it for an hour or two, then when I come back it seems to go easy. Good luck man!
Edit: If the other bolts are already loose, tighten them back down. If that one bolt is the only one holding the head down, there is more pressure against it. Just a last second thought.![]()
Good idea...I'll try that (the others are all loose).
