Results 1 to 5 of 5
Thread: p0507
    Victoria, TX
    p0507
    throwing this code, high idle RPM
    I noticed after swapping the throttle body to a ported and polished unit a couple months back that it idled higher, a little over 1100. But its just now showing the code could it be the combination of me having the tuner increase the idle a small amount and then the p&p TB causing this or should I look into replacing some of the sensors?
    2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
    if you have a cable type TB you probably just need to adjust the stop screw.
    College Station, TX
    I had to play with my screw a ton just to get it right so it wouldnt throw codes or idle funny. Ported TBs can be a P.I.T.A.
    Throw codes?
    LOL, that's what D**** and F*** guys say.
    1100 is way too high without a total aftermarket program or computer system.
    College Station, TX
    The only code I had when trying to finish my ported TB was reduced engine power but then again I have dbw. Then when I fixed that it idled to high. You just have to mess with that screw to get it right man ha
