Results 1 to 10 of 10
Thread: 93 octane NP tune, transgo shift kit & vette servo in today..
    Feb 2008
    Arizona
    i got up this morning at 6 am.. i bet that happens to you all the time when you have your truck getting some performance upgrades done.. anyways, im waiting for the mechanic to open the shop to take him the tranny oil.. i bought royal purple oil for the tranny, he just installed the transgo hd2 shift kit and the vette servo... after that i will go to the dealer to ask the mechanic to install my nelson tuned pcm for me.. 2 questions here..
    is Royal purple oil, worth the price?
    is it the same to install a brand new pcm than Nelson's?? is the same relearn process?? thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Put stock tranny fluid back in it if you use it for performance. That Royal Purple can be too slippery at times. The stock stuff costs a lot less and makes it more affordable to refresh more often.
    SA, Texas
    I happen to like Royal Purple!
    Felix,
    Its just plug and play!
    You might or might not have to do a Sercurity Relearn Procedure.
    Nelson Performance - Security Relearn for no start
    thanks
    melissa
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    Feb 2008
    Arizona
    I really hope so!! cause im not that good with english so i have a hard time with the relearn process and that stuff.. but, once again.. i hope i just plug and play!!
    hum.. so royal purple it or not??
    Does Allen put Royal Purple in transmissions he works on?
    Feb 2008
    Arizona
    i just called up my friend who was supposed to bring me the royal purple oil from the US, and he say he only brought the engine oil... cause he went to pepboys and couldnt find royal purple oil for the tranny.. so.. i'll go to an autozone to buy it right now.. should i buy regular oil? or should i buy syntetic oil??
    Aug 2005
    St. Anthony, Indiana
    regular oil for the tranny
    SA, Texas
    I personally like Royal Purple but my fiance chooses Valvoline Max Life Synethnic Blend to put in our Pickup.
    Allen does use Mobil 1 for his vehicles!
    Her name is A Meli-
    Mobil 1 Ftw!!!!!!!!
    ff_jeff Guest
    I used redline last time and It runs allot better now. quieter too.
