Results 1 to 5 of 5
Thread: 06 4l60e to 98 5 speed 5.7 vortec
    Jul 2007
    how hard and any tricks. Also do i need a different wiring harness
    also its a 96 4l60e
    Yes, a new wiring harness is needed. And it should bolt right up...but there is other stuff to worry about--column shifter and cable, tranny cooler lines, drive shaft, PCM, etc...
    ff_jeff Guest
    Quote Originally Posted by tatrojan06 View Post
    also its a 96 4l60e
    -- oh for a second I thought you were putting a lt into a 2006, i was like "say what?" but din i was like "oh"
    I think the tranny will bolt right up, youll have to worry about the shifter though, and the drive shaft might not be the same length, but im not sure on that one. I think it would be fairly easy.
    ff_jeff Guest
    you are talking about putting a 5speed from a 98 into a 96 truck that is auto right? im pretty sure itll be smooth.
    Broken Bow, OK
    I did it in a 96 for my dad in a farm truck and put a NV4500 in. I just left the selector module for the auto trans plugged into the harness and made it think it was in park all the time and spliced in the VSS. I just took the shift lever off the steering column.
    Ghetto way to do it, but it worked and it was a farm truck so we didn't care.
    To do it correctly you would really need a donor truck.
