Results 1 to 10 of 21
Thread: Broken Valve Springs on LT1 TrickFlow heads
    Oct 2007
    HELP PLEASE!!!
    Any witch doctor is welcome......
    I installed my shinny trick flow heads on my LT1 ( TFS-30400010, 1.460" Dual Springs) and a CompCam DURATION # .050 230 230 GROSS VALVE LIFT .583 .583 114 LS
    After a few miles of use, not hard core, I busted a OEM rocker arm in the tip zone !!!!!!
    Thinking it was my good luck I replace it, and ordered the CompCam full roller rockers and chrome molly push rods.
    When I say few miles, I mean it, so the stuff arrive, and when I'm ready to change them, I notice 2 valve springs that went south !!!!!!!!!!!
    Now, I'm clueless about what is happening here, I can order new springs, but my logic says that I'm not addressing to the source of the problem.....
    I'm always been a change parts type of guy, no real mechanic for what this problem calls for....can any one please guide me, in what should I change or look for in the valve train?
    I was so ready to install my PTK turbo kit, but now, I'm stalled and scare to death...
    Thanks in advance for any tip.
    With that much lift on a stock LT1 you probably crashed a valve into the piston tops.
    Oct 2007
    Dear Redheart,
    The heads R 62cc combustion Chamber, I'm guessing the OEM is around 58cc or 60cc....but u r the master here
    If I send a valve to meet a piston, wont that bend a valve, or a push rod, but not break a spring, thank for ur input and please guide me here.
    Also the Cam ant the turbo sys and almost every mod was consulted and aproved by Allen. But as ussual, he's out of reach
    Even the stock LS1 springs can't handle that much lift. How much lift are the springs on those heads good for? Did you clay the piston tops for clearance before you finish torqued the heads on? Checking the piston to valve clearance is very important. If you have the heads off be sure to check the clearance this time around.
    I see its .600" max lift.
    Oct 2007
    Greg,
    the springs came in the heads and R good for 438lbs./in. and install height 1.800
    I think I have no prob with the valve clearence, but, the heads r mounted......is there anyway to check clearence without the clay proses in mounted heads?
    Oct 2007
    .583, Am I inside the safety parameters?
    It's close but safe on the lift amount. The valve to piston clearance is what I'd be most worried about.
    Oct 2007
    Greg,
    Let say the valve touch the piston, would that break the springs?
    Would the OEM push rods survive that?
    I reved the engine loaded to 6800 rpm !!!!!! Allen tune
    Oct 2007
    thanks for all your advice, tomorrow we are going to dissassemble the heads and check if there was any contact between the pistons and valves
