Thread: E-Fans
    E-Fans
    Hey guys I am looking to install a set of LS1 fans on my truck. And looking for some tips. My rad. measures just over 28" wide. Just wondering how you have been mounting them. Any pics would be great. Oh yeah did I mention that I cant weld, hopefully fabrication is not needed.
    99 excab, Nelson Tune, k&n FIPKII, pacesetter long tubes, No Cats, Dual Magnaflows with turndowns,
    1/4: 15.66@88.1 Before Nelson, headers, and de-cating
    Also 69 camaro SS 350 4speed, 13.81@103.6, Ls1 swap planned
    I go to Autozone and buy radiator tie/zip lock mounts to hold the radiator to the fans. You drill a little hole some place out of the way of the fans and then push the retainer through the hole and then in between the radiator fins, through to the other side and then install the foam, retainer and lock. Put about 6 to 8 of them evenly spaced and it will hold fine. Some guys get strap iron and make a mount to bolt it to the radiator core support instead.
    That sounds great for me because of the lack of Fab experiance. Thanks.
    If any one has some pictures of the after I would love to see them.
