Thread: 2007 DENALI Trans Mod's?
    Jun 2007
    Are there any Transmission Mod's available for the Denali, such as servo's, a bigger converter that's stock (like a suburban one) maybe? this vehicle has an extended warranty, so no huge aftermarket mod's. A nelson tune will prolly be added as well.
    05 5.3 RCSB, K&N CAI 77, MSD 8.5's, NGK's, NELSON TUNE, 2"-4" G-Force, HKR Max Flow, TB STALL, 28k Cooler, Vette Servo, 160 Stat, Xenon lamps EveryWhere, 10k H.I.D's, Smoked LED 3rd brake Light, Smoked Tail's, 15% Tint, 45% WS Tint
    1967 Nova 358 ci Dart Pro 1 Heads Port matched to Vic. jr, 250/256 solid cam, Hooker Headers ceramic coated, Super Street Fighter Stall, Hipsters Transbrake, 9 inch w/ 4.11's, 26x10.5 Et streets, Lo-pro Caltracs
    Which transmission does it have?
    Quote Originally Posted by Fuj357racing View Post
    I'm pretty sure it has the 6L85E, which I'm pretty sure nobody has tried to install a servo.
    Once hptuners releases the trans calibration (shift firmness) you'll be able to make that trans shift as hard as you want to and have complete control.
    A servo in an older 80E is too much in my opinion and hits too hard.
    For the 6L85E, it's going to hit just as hard, I wouldn't install anything just yet.
    Removing TM will allow that trans to hit harder. Being that the Denali is a "luxury" truck, they have tons of TM.
    hope this helps,
    allen
    Feb 2005
    San Antonio Tx
    TM = evil
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    hope this helps,
    allen
    installing a servo would be hard to do on this trans,,,it doesn't have one. this trans has one sprag and all the rest are clutch packs. there isn't a band to install a servo onto. it works simmilar to a allison,one clutch comes off and another one comes on, it takes two to make it move. when a tuner comes out for it you will be able to adjust all the shift feel you want.
    hear is a description of how it works
    Transmission General Description
    The Hydra-matic 6-Speed RWD is a fully automatic, 6-speed, rear-wheel drive, electronic-controlled transmission. It consists primarily of a 4-element torque converter, an integral fluid pump and converter housing, a single and double planetary gear set, friction and mechanical clutch assemblies, and a hydraulic pressurization and control system. There are four variants of the transmission, all based on torque capacity. Architecture is common between the variants, and component differences are primarily related to size.
    The 4-element torque converter contains a pump, a turbine, a pressure plate splined to the turbine, and a stator assembly. The torque converter acts as a fluid coupling to smoothly transmit power from the engine to the transmission. It also hydraulically provides additional torque multiplication when required. The pressure plate, when applied, provides a mechanical direct drive coupling of the engine to the transmission.
    The planetary gear sets provide the 6 forward gear ratios and reverse. Changing gear ratios is fully automatic and is accomplished through the use of a transmission control module (TCM) located inside the transmission. The TCM receives and monitors various electronic sensor inputs and uses this information to shift the transmission at the optimum time.
    The TCM commands shift solenoids and variable bleed pressure control solenoids to control shift timing and feel. The TCM also controls the apply and release of the torque converter clutch which allows the engine to deliver the maximum fuel efficiency without sacrificing vehicle performance. All the solenoids, including the TCM, are packaged into a self-contained control solenoid valve assembly.
    The hydraulic system primarily consists of a vane-type pump, 2 control valve body assemblies, converter housing and case. The pump maintains the working pressures needed to stroke the clutch pistons that apply or release the friction components. These friction components, when applied or released, support the automatic shifting qualities of the transmission.
    The friction components used in this transmission consist of 5 multiple disc clutches. The multiple disc clutches combine with one mechanical sprag clutch to deliver 7 different gear ratios, 6 forward and one reverse, through the gear sets. The gear sets then transfer torque through the output shaft.
    The transmission may be operated in any of the following gear ranges:
    PARK (P): This position locks the rear wheels and prevents the vehicle from rolling either forward or backward. PARK is the best position to use when starting the vehicle. Because the transmission utilizes a shift lock control system, it is necessary to fully depress the brake pedal before shifting out of PARK. For safety reasons, use the parking brake in addition to the PARK position.
    REVERSE (R): This position allows the vehicle to be operated in a rearward direction.
    NEUTRAL (N): This position allows the engine to be started and operated while driving the vehicle. If necessary, you may select this position in order to restart the engine with the vehicle moving. This position should also be used when towing the vehicle.
    DRIVE (D): Drive range should be used for all normal driving conditions for maximum efficiency and fuel economy. Drive range allows the transmission to operate in each of the 6 forward gear ratios. Downshifts to a lower gear, or higher gear ratio, are available for safe passing by depressing the accelerator or by manually selecting a lower gear in the manual mode range.
    MANUAL MODE (M): This position allows the driver to select a range of gears appropriate for current driving conditions. Refer to the vehicle owner's manual for specific manual mode information.
    Transmission General Specifications
    Name
    6L80
    RPO Codes
    MYC
    Production Location
    Ypsilanti, Michigan (USA)
    Transmission Drive
    Rear Wheel Drive
    1st Gear Ratio
    4.027
    2nd Gear Ratio
    2.364
    3rd Gear Ratio
    1.532
    4th Gear Ratio
    1.152
    5th Gear Ratio
    0.852
    6th Gear Ratio
    0.667
    Reverse
    3.064
    Torque Converter Size - Diameter of Torque Converter Turbine
    258/300 mm
    Pressure Taps
    Line Pressure
    Transmission Fluid Type
    DEXRON VI®
    Transmission Type: 6
    Six Forward Gears
    Transmission Type: L
    Longitude Mount
    Transmission Type: 80
    Product Series
    Position Quadrant
    P, R, N, D, M
    Case Material
    Die Cast Aluminum
    Transmission Net Weight (Approximate)
    100 kg (220 lb)
    Maximum Trailer Towing Capacity
    Refer to applicable owner's manual
    thanks, we'll use this as info on another section.
