Results 1 to 10 of 25
Thread: Turbo Grind cam has got to go!!!
    Comp Cams Extreme Energy FI Cam $250+shipping
    Used Comp Cam for turbo applications. 8000 miles. This is an Extreme Energy model with the very aggressive ramp angles and is designed for forced induction only. You will lose HP if you attempt to use this cam in a naturally aspirated engine unless you're running nitrous on an almost race-type engine. Specs are...
    SERIAL # D 8917-05 SPEC CARD # 07125505
    PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
    CORE C54-11I CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special
    Grind
    GRIND # LS1 3730 /3724 HR113+2
    DURATION @ .050 INTAKE 240
    DURATION @ .050 EXHAUST 228
    LOBE LIFT INTAKE .3580
    LOBE LIFT EXHAUST .3460
    VALVE LIFT INTAKE .608
    VALVE LIFT EXHAUST .588
    LOBE SEPARATION 113.0
    DURATION .006
    INTAKE C/L 111.0
    TAPPET LIFT INTAKE 289 degrees
    TAPPET LIFT EXHAUST 277 degrees
    CAM ADVANCE 2
    VALVE TIMING .050
    VALVE OPEN INTAKE 9
    VALVE CLOSED INTAKE 51
    VALVE OPEN EXHAUST 49
    VALVE CLOSED EXHAUST 1-
    JOURNAL DIAMETER STD 2.165
    INTAKE LOBE ID 3730
    EXHAUST LOBE ID 3724
    DATE SETUP 01/25/2005
    $250 plus shipping. Local pickup available in the DFW TX area.
    May 2006
    Waco TX
    I wonder if it would work in 6.0?
    Yeah, it will work but if you don't have forced induction, you'll lose power. It makes more HP than a normal cam would in an FI application but less in an naturally asprirated engine. The cam is designed to take advantage of the pressurized air pushing the fuel through the cylinders. The cams that guys are running with a 224/224 duration work better than this cam if you don't have FI. If a turbo is in the works, I'd go for it. Comp said that it's one of their best turbo grinds.
    Jan 2006
    Is this the cam you were currently running Red? Why would you lose hp? I mean I can see not getting the full potential out of your engine but actually losing hp over stock... ?
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Jun 2006
    I guess is cause the cam is design to hold compresion, probably is slowest that the original cam, cause is waiting for someone to make the job of pushing the air in and out.
    The N/A cams most do this on Atmosfere presure, so the ramps most be fasters to let the air go out and let more air to go in........just guessing.
    On my 2wd truck I'm going to STS, Allen told me I have to change my cam to take adventage of the GT67 turbo.....Do you think that cam would help me?
    Need a Freakin' Roll Cage, and a Death Insurance
    Oh yeah, it sounds sweet too. You'll need springs that will handle the lift but it's an awesome cam. When I sprayed the NOS, the engine was a beast. It was recommended by Comp that I go back to a different cam since 99% of my drive time is naturally aspirated. They told me that the cam could still be a benefit if I was doing nothing but racing this engine and spraying NOS or using some kind of forced induction but they suggested a whole new profile for the 408 engine.
    <div class='quotetop'>QUOTE(motoxlifer &#064; Aug 18 2006, 09&#58;01 AM) [snapback]61576[/snapback]</div>
    Yeah, that was the cam I was running. The design was intended for a totally different purpose than what I was using it for. Comp told me to expect HP losses using that cam NA. With spray or FI it is hard to beat the profiles of that cam.
    http://s47.photobucket.com/albums/f197/red...=headers038.flv
    A little sound bite of the cam running NA.
    Jan 2006
    Not trying to argue or anything, but I just can&#39;t see a cam with that much duration and lift over stock regardless of it&#39;s profile or intended use causing a loss in power over stock.
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60&#39;] &#39;98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes &#39;98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,&#33;EGR,&#33;cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73&#39;s w/Auburn posi; Eclipse CD, Rockford 6 1/2&#39;s, Memphis 12&#39;s, Punch 200 ix, Punch 500x
    That&#39;s why they won&#39;t let us design camshafts.
    Feb 2006
    MIZZU
    I&#39;m very interested.
    What springs and pushrods do I need for a stock &#39;99 5.3 with the STS kit.
    Are you selling just the cam or do you have springs?
    Thanks, TY
    1999 Silverado Z71 RCSB with 2006 LQ4 6.0, Comp Cams 220/220 581/581 115lsa, STS, methanol, Nelson street tune, 160* stat, 2006 E-fans, FLT 4L60. 12.53 @ 107 on 5psi
    I am running Manley dual springs with titanium retainers. They are staying for the new cam since it&#39;s going to be over .600 lift. Comp 918s aren&#39;t big enough for this cam. Billy at TRTTURBO can get you a nice set of Patriot Performance high lift springs for a very good price.
    You&#39;ll need 7.4" long hardened pushrods for pretty much any comp cam.
