I have a 84 stepside that I put a 5.3 in. I used the original style radiator that is a 3 core aluminum style that I added the fittings to it to match the 5.3 type rad. I have the coolant res. mounted on the fenderwell like stock. My problem is driver side of the rad. gets extremely hot (can't touch with hand) and the pas. side is ice cold. Temp. gauge runs one mark past 210 deg.(225?) I have read other posts about filling through upper hose, milking the hose burping tried them no better. My temp. sending unit is mounted in the water pump. I have put on new pump, thermostat, sending unit, still the same problem. changed fans tried manuel electric no better. As far as I know the moter has never been tore into. Any help would be appreciated, Thank you Danny
