Results 1 to 10 of 11
Thread: tahoe sideview mirror glass
    Oct 2005
    Houston, Tx
    i was wondering about how much a mirror assembly would be. or if you can just get the glass part? not cracked too bad but kinda a pain in the ass the see a crack in the middle.
    Aug 2006
    Wisconsin
    with or without turn signal/heat?
    brad - my fquick..
    curb feelers and fuzzy dice..
    Oct 2005
    Houston, Tx
    heat ..no signal. its a 2001
    DBYRD Guest
    <div class='quotetop'>QUOTE(TXcrew &#064; Oct 31 2006, 07&#58;03 PM) [snapback]71789[/snapback]</div>
    sounds like daniels ss, barely noticeable, but frustrating knowing its there. u cant see his usually unless u try pretty hard, but again just frustrating. i think u can get the glass part somehow.
    Oct 2005
    Houston, Tx
    cool..i hope so..
    Jan 2005
    Conway, AR
    You can order the glass itself, heated, signal, or not. My no heat no signal cost &#036;25 installed from a local auto glass shop. Just find one and they should be able to hook you up&#33;
    I know Napa can get you the glass. Heated, don&#39;t know.
    Apr 2005
    I took out mine at about 70mph with a construction barrel. Housing was fine, but the glass vaporized. I jsut went to the dealer & got a new glass. It just push-locks in place.
    Gone, but not forgotten!
    Oct 2005
    Houston, Tx
    <div class='quotetop'>QUOTE(SCIV &#064; Nov 1 2006, 08&#58;26 AM) [snapback]71835[/snapback]</div>
    cool.. ill call them today.
    Jan 2005
    Conway, AR
    You got the plate behidn the actual glass piece didnt you? How much did that run? I just got the glass and they had to glue it to the thing that locks in the mirror.
    Chris
