Hey, I am fixing to order 5psi turbo kit for my truck and was wondering if anything else should be modified before install? For instance, torque converter? Injectors?. Thanks, any help and experience would be gladly appreciated.
2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
What do you own, what mods have you done and where are you going in the future?????
The MADNESS NEVER ENDS![]()
Welcome to the forum....![]()
I own a 2000 Silverado with the 4.8L.Bone stock except for 3.96 gears and cold air intake.I plan on making the truck a daily driver. I want the power there to use when I am feeling gunny!<div class='quotetop'>QUOTE(jethro_3 @ Aug 7 2006, 06:53 PM) [snapback]60316[/snapback]</div>
Defintley fuel pump and injectors. Call Nelson performance for a great deal on injectors, call magnuson for a "RADIX" in tank fuel pump kit. Also get yourself a dual or tripple A-pillar pod for a boost gauge and a Wideband, youll need it. An Interceptor gauge is Very Helpful, Allen has the best deals on Widebands and Interceptors also. Then save up and upgrade your tranny with a shift kit/ servos then your going to need new psi cause the G-80 sux then you need .............. Dont worry bro, 1 step atta time! your gonna love that turbo!!!
<div class='quotetop'>QUOTE(Tim Z @ Aug 7 2006, 08:02 PM) [snapback]60328[/snapback]</div>Thanks man! What do you think of my ride?Defintley fuel pump and injectors. Call Nelson performance for a great deal on injectors, call magnuson for a "RADIX" in tank fuel pump kit. Also get yourself a dual or tripple A-pillar pod for a boost gauge and a Wideband, youll need it. An Interceptor gauge is Very Helpful, Allen has the best deals on Widebands and Interceptors also. Then save up and upgrade your tranny with a shift kit/ servos then your going to need new psi cause the G-80 sux then you need .............. Dont worry bro, 1 step atta time! your gonna love that turbo!!!
[/b]![]()
If you have a g80 rear end, swap it out before you blow it apart.
