I'm putting a 99 5.3 in an OBS and was wondering the best way to get a serpentine belt seup on it. Can someone give me some direction? All help is appreciated, I'm an old small block dude!
81 REG CAB SWB; 5.3, 4L60E UPGRADE
The engine should come with the serpentine belt assembly. The truck setup works nice. Finding a setup in a salvage yard is tough unless you can pull the assembly off a core engine. Most won't let you have the serp setup off a complete engine assembly.
id use the OE factory serp setup.
if you plan to run air conditioning, this will be a lil hassle as the compressor will
force a lil frame notch...
airdeano
1965 C10 5.3L/4L60e (300HP 4-Speed)
http://home.comcast.net/~airdeano/1965/img/196531.jpg
http://home.comcast.net/~airdeano/1965/index.htm
If you like street rod setups, www.hotrodlane.cc can set you up with some sweet billet accessories. If you want stock, they sell takeoff accessories, also. They make a high-right side a/c bracket using the Sanden 508 compressor. That's what I run on mine with Fbody accessories. They make a truck bracket for the a/c mount, too.
