Results 1 to 9 of 9
Thread: Update on the beater
    Nov 2005
    The truck is running smooth now. But' will not shift. Ya'll where right, it has to be starting out in 2nd or 3rd gear. It was hard to tell since I never drove the truck before. ( Plus having 3.08 in it)
    There is a yellow wire and a purpel w/ white strip wire that was cut. The wire's are coming from that round plug on the trany. I need to find a wiring diagram to see where they go.
    Let me now what you find REDHARTBEAT when you get home.
    Thanks guy's for all the help w/ my project.
    SOON TO COME!!!!
    Connector layout for 4L60E transmission plug as view looking at the female connector that is mounted in the transmission...
    A B C D
    E
    L M N P R S
    T U
    A = 1-2 SHIFT SOLENOID-A (LOW)
    B = 2-3 SHIFT SOLENOID-B (LOW)
    C = PRESSURE CONTROL SOLENOID-HIGH
    D = PRESSURE CONTROL SOLENOID-LOW
    E = +12VOLT INPUT TO BOTH SHIFT, 3-2 CONTROL AND TCC SOLENOIDS
    L = TEMPERATURE SENSOR INPUT (HIGH)
    M = TEMPERATURE SENSOR GROUND (LOW)
    N = PSM RANGE SIGNAL "A"
    P = PSM RANGE SIGNAL "C"
    R = PSM RANGE SIGNAL "B"
    S = 3-2 DOWNSHIFT CONTROL SOLENOID (LOW)
    T = TCC SOLENOID (LOW)
    U = was connected on my truck but unsure where it went in the transmission
    connector from 99+ LS1 4L60E to PCM connectors...
    A = LT GREEN WIRE TO RED 48
    B = YELLOW/BLACK TO RED 47
    C = RED/BLACK TO RED 6
    D = LT BLUE/WHITE TO RED 8
    E = PINK TO BLUE 19
    L = YELLOW/BLACK TO RED 51
    M = BLACK TO BLUE 53
    N = PINK TO RED 63
    P = RED TO BLUE 18
    R = DK BLUE TO BLUE 17
    S = WHITE TO BLUE 79
    T = TAN/BLACK TO RED 42
    U = BROWN TO RED 2
    Test resistance values
    E & A = 1-2 SHIFT SOLENOID = 20-40 Ohms
    E & B = 2-3 SHIFT SOLENOID = 20-40 Ohms
    E & S = 3-2 CONTROL SOLENOID = 9-14 Ohms
    E & T = TCC SOLENOID = 20-40 Ohms
    C & D = PRESSURE CONTROL SOLENOID = 3.5-8 Ohms
    L & M = TEMPERATURE SENSOR = 2.9-4.0 kOhms
    Nov 2005
    Thank you redhartbeat.
    SOON TO COME!!!!
    Get a scanner on the truck too, if the pcm isn't getting any vss signal, it will not shift right. I experienced that on my first install on my truck, a looong time ago. The truck wouldn't shift until 4Krpms and it was inconsistant.
    keep us updated,
    btw, why still running that harness, you need something else
    you'll get it, just stay on it,
    allen
    Looks like your on your way to sorting this out. If you still have problems once you get your wiring figured out let me know. I have the flow charts for this. Tells you what do step by step and what to do if Ohms are out of range and what to test next Ohms to ground etc.. I would have to fax them though as Alldata wont let me copy/paste or save it to disc.
    Apr 2005
    springfield MO
    my swap I used a painless harness, I had misread the instructions since it came with plugs for the 4l80 and 4l60. I hooked up the in to the out or something like that and it did like Allen said it shifted at 4 grand, I reread the instructions and got it hooked up right and it has been fine ever since. Well except when I go to second gear there is this squeeling sound I get from the rear area of the truck. well come to think of it it happens when I take off too, depending on the weight of my right shoe it varies in intensity
    good luck.
    1968 Chevy SWB Fleet. 2002 5.3 all stock (for now ) Nelson Tune 4l60e w/TB converter.
    ok not stock anymore...13.3 at 101
    Now with front mount turbo... new times soon
    Nov 2005
    keep us updated,
    allen
    If I had the money I would have bought one your bad ass harness from you along time ago. If I would of had that harness this truck would have been running 3mth's ago.
    Thank's Allen.
    SOON TO COME!!!!
    Nov 2005
    The purple wire and the yellow wire where not coming from the round conector. They are coming from the large rectangel conector above the shift lever. Any ideas what these are?
    At the PCM M = BLACK TO BLUE 53 / M = TEMPERATURE SENSOR GROUND (LOW)
    is cut. Also blue 49 VSS 128k Out YEL/BLK (pin E of blue 12 pin connector) is cut from the PCM will this make it run bad?
    I pulled apart most of the wiring everthing else looks to be OK. If what I found isn't the problem I guess I'll be trying to find someo one w/ a tech II.
    How can I tell if it's just the shift module thats bad?
    SOON TO COME!!!!
    The transmission temp wire needs to be repaired. You go into limp mode because the PCM doesn't know if the trans has overheated or not so it should go into safe mode. Purple and Yellow are the feed lines to your speedometer.
