Results 1 to 10 of 12
Thread: New engine break in procedure
    Feb 2005
    Austin, Texas
    How hsould I break in my new 418 once its all together I have gotten so many opinions its not even funny. Allen how do they break them in at Nickens?
    Drive it the way you plan to drive it in the future. If you baby it during break in some say it will more likely die a premature death later when you mistreat it.
    Sounds like you're ready to start it, that's great!
    Simply turn the engine over until you get oil pressure. Then hook up the whatever you decided to remove so it wouldn't start, then start it up.
    Let it warm up, take it easy, a few half throttle runs, if everything seems right, no noises, leaks, go ahead and get on it. Make sure there isn't any pinging or a lean condition and you're good to go.
    That's the way it's done.
    good luck,
    allen
    Dec 2003
    Newark, Tx.
    When we have a motor built, we flog the crap out of it at the dyno after driving it about 30 miles. Even out engine builder said its fine.
    Oh yeah, I forgot about initial startup. I always leave the plugs out and crank the engine until I have oil pressure reading at the guage. Also be sure you prefill the oil filter before installing it. As for an oil pump, the LS2 pump puts out 20% more than a LS1/LS6 pump and Lingenfelter even recommends that pump for the aftermarket crankshafts now. The pn is 12571885 if interested. $72.72
    Don't be a dumbass like me and install the engine in the truck with the filter installed and then dent it and end up killing your engine!
    San Marcos Texas
    Originally posted by RedHeartbeat@Dec 13 2005, 08:37 PM
    Oh yeah, I forgot about initial startup. I always leave the plugs out and crank the engine until I have oil pressure reading at the guage. Also be sure you prefill the oil filter before installing it. Don't be a dumbass like me and install the engine in the truck with the filter installed and then dent it and end up killing your engine!
    Talk about engine Broken IN!
    Dec 2003
    Newark, Tx.
    You can just unplug the connector to the coils on each side and spin it over 10 seconds or so to get the oil circulated.
    Feb 2005
    Austin, Texas
    I get the block back on friday to start putting it together so it shouldnt be too long hopefully. My buddy whos house I ahve been doing all this blew his blonw 4.8 today so it looks like we will get mine together then be pulling his and rebuilding it the viscious cycle never ends
    Yeah Ill disconnect the two main coil pack plugs and do that.
    Red I already ahve a ported LS6 oil pump thats going on it
    Should I change the oil after say 50 miles or so thats what I ahve gathered in all my searches and talking to people.
    Dec 2004
    Andrews, NC
    Make sure to run normal castrol oil in it so your rings break in good and I would change the oil after say 1000 miles just to make sure the engines clean. Good luck with it...
    lator
    Justin
    2002 GMC Seirra scsb, 5.7LS1, Twin 62-1 turbos, Compcam 222/218, 4l80e, and Hptuners
    2006 GTO Black/Red, 6.0 M6, 238/240 cam, SW LT, exhaust & bolt ons = 438rwhp411rwtq!
    Feb 2005
    Austin, Texas
    Going to run some regular oil with EOS the ring breakin shit that you can get from GM. Then change it after 50-100 miles then change it at 500 then at 1000 to Royal Purple I know its a bit over board but I spent too much money to screw it up over a damn oil change IMO.
